Does anyone know if Brembo makes rear slotted rotors for a P11?
If so and where would I be able to find them?
I've been searching for half the day online and have searched on gnet
but found nothing so far.
If they do make rear slotted rotors for the Sentra, will this also work for the G?
Where are some places online to buy the Brembo slotted rotors for a good price?
the places that i always tend to see the slotted /drilled rotors for the p10 / p11 are on ebay here are a few links for you
http://cgi.ebay.com/ebaymotors/Infi...ryZ33564QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/INFI...ryZ33564QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
to answer your other question no you can't use 91-99 sentra rotors as they are a 4x100 bolt pattern. if you used spec-v the bolt pattern is right but not sure about the size of the rotor
hope it helps
joe
Thanks, I'm looking specifically for Brembos, I know Powerslot
uses Brembo blanks and slots them, but the Brembo slotted ones
are made from a different metal.
