Any modifications needed for 02-06 Sentra spec v Brembo upgrade for p11?
Brake lines would bolt up as well? Or should i upgrade them too
Do you have link for that? also I can’t find any listings on spec v rear calipers any where, do you know where I could probably find them? or should I just upgrade the rear rotor to the spec v with the maxima bracket and leave stock calipersBrake lines also bolt up just fine, however it makes for a good time to upgrade to SS braided lines. I found a set on ebay for like $75.
Makes sense, im already looking for what I need new stop tech lines are $147 on eBay so might as well but would I still be able to get rear calipers if I want to upgrade the rears through brembo? They’re website is confusingIf your rear calipers are good, I'd just get the brackets.
However, I'd get new SS lines. Rubber has an age limit, and our cars be getting up there. Also, since you need to crack the system open to replace the fronts, might as well do lines and bleed everything once and be done.
