So after some extensive research of how's and why's... @Doug fab & I decided to build a Gear cuffs to utilize on the P11, 2000-2002 like all of the drag Hondas. This braces the gears together to prevent less/no separation at high RPM, which normally leads to spinning the gears. The downside is that you will loose 5th gear. With the gear ratios and FD of the P11 @ 8400RPM in 4th with a 24.5" Tire your MPH will be around 161mph. Let me know what you guys think.
