What bypass module are you using? How is it wired up?Thanks I will look at that. It cranks but doesn't start![]()
Is the bypass activating before ignition power? It should be... Commonly a ground while running or a status output is used to trigger the bypass.I'm using their's (791) 12v constant, Ground, and bypass then the loop around the ignition
