1 - 7 of 7 Posts
Hi all,
I live in Taiwan and it rains often here and when it rains I mean it rains. The roads do not drain well so there are many large pools to wade through sometimes.
IF I installed a CAI I would of course try to avoid as many of these polls as possible, but the question is:
Should I install a CAI or a WAI? If CAI, is there someway to "protect" the airfilter from getting terriblt soaked?
Perhaps some of you might have the same problems and have found a way to avaid damaging the air filter.
thanks,
Bob
Thanks,
that may be the answer I will need.
As for PC520 I sent you a PM. Perhaps a Wai Gwo Ren can be a member of the club.
Thanks both of you.
i wouldnt worry unless you are actually dipping the filter into the puddles ....otherwise you should be good.Get the AEM thing if you are worried
1 - 7 of 7 Posts
