1 - 10 of 10 Posts
are cams a good mod on there own meaning with no other mods and if not what other mods should be done before the cams sorry if this is a stupid question:sleep:
Not a dumb questions. But yeah, they are fine alone. They do work better with a header and exhaust though.
yahool said:
thanxs how about a throtle body is that a good mod with cams
No. Not much to gain with a NA SR20DE and bored out throttle body. Spend the money elsewhere.
can i get a mod list in the order best recomended cause i know when you put something you have to do other things sometimes and i dont know everything it not that much what but in what order:nervous:
My prefered order is: intake, exhaust, header, pullies, cams...I could go on but we are getting into turbo territory here. Not to mention you can search for my turbo plans that kind of pick up from here.
my two cents are advanced timing, pulleys, intake, header, cams (retard timing at this point) then exhaust....either way, youll still get to the same place...
oh and also all these mods that fit my engine would they fit ser20det cause enentualy i want to swap in the furture
yahool said:
can you get a pulley for auto or is it for stick
It doesnt matter
Do your homework, if you plan on going turbo...dont waste money on stuff that youll have to replace, like a Header...youll need a whole new one with that.....plus a ton of other *goodies*
1 - 10 of 10 Posts
