Got the g started finally then turned the idle down cus it wanted to start at 2k and now it just wants to bog down and flucuate from 700-900 rpms. Was gonna do the timing procedure but it dies as soon as I unplug my tps which means the base idle must be too low. I made sure to bleed and burp the coolant so I don't think there is any air and I can't find any vacuum leaks. At my wits end
