whats good... aight check it on tuesday my car didnt start i checked everything and i found that my spark plug wires were bad..... i replaced them.... then the next day on my way to work it just started to bog on me and then it died.... can anyone tell me whhy??
I'm Better Than Zohaib
Edit: sorry about the pic ^ but i just wanted to use it really bad lol
sounds like its the belt thats running to the alternator, check to make sure its even there... and it could even BE your alternator... your battery is probably dead now too...
p10 guru
you need to give us alot more info. it could be anything from your description
*edit: if your spark plug wires were bad, there is a good chance you need a whole tuneup
does it crank? does it just click? do your headlights work? does nothing happen?
p10 guru
like i was sayin, probably be a good idea to give it a full tuneup, before you end up on the side of the road. that might suck, being as cold as it is.
