1 - 20 of 25 Posts
JDMike!!!
Alright guys i am going to start another GB..this time it will be for BOTH p10 and p11... all the bars i got for the P11 fit well and perfect!...it was also Tested in my car before i shipped it out...
I believe Japan does not have any low-ports for their P10s. Will this effect p10s that have low ports (93.5+)? Will it fit the FSTB?
if you have installed a carbing stb(front or Rear) in a p10 (Please specify high/low port and year too). Please tell us how it went and what problems u have faced...(I read about the Rear STB (stangG20 and chino88) install
Please help me out...
mike
sign me up, if this is going for sure...BTW these bars will fit only high port P10's
Rob
how much is this going to go for? I was thinking of getting Octotats RSTB but if this is cheaper then maybe I will get in on this. Damn me having the lowport...I would so take the tri-bar...what about pricing on the cooling plate for the p10?
Hey if it might be alright with whoever buys a cooling plate for the p10, maybe open it up first to see the fitment on a p11?
I don't know the differences under the hood, but it can't be too much of a difference...
Low port started in 94, so 93.5 are still good to go.
I have a carbing rad plate for the p10. Although I haven't tried, I can't imagine it would fit a P11. the way the radiator support / grille / hood / hood latch is completely different as the p11 has the grille built into the hood and it goes down further. I don't think they make a p11 plate for that very reason.
JDMike!!!
Discussion Starter · #17 ·
thanks for clearing up with us
Octotats RSTB is a replica of carbing...also he did a few more mods to make it fit better...
Carbing is more than octotats...
p10 guru
im pretty sure octotats rstb is different than the carbing. afaik, his bar is in the trunk, while the carbing sits above the rear deck inside the car
1 - 20 of 25 Posts
