ive just changed the clutch and gearbox on a 96 g20,now it turns over but wont start. i have a good spark and fuel to injection system! :-\ any ideas ,would be grateful
If you have spark at the spark plugs, and fuel going into the cylinders then the engine should start.
Make sure the iginition timing is set correctly. Make sure you have fuel actually going into the engine cylinders.
There is a switch (relay?) on manual cars that prevents the engine from turning over unless the clutch pedal is depressed. But it sounds like your engine is turning over.
No dozy twat switches on the clutch on UK cars ;)
I'd just say check everything over, all connectors plugged in, all vac hoses connected etc. It can't be much really, a clutch and g/box swap shouldn't cause any electrical problems.
