hey guys i need some help with my p11. I keep getting a fault for egr valve which triger the check engine light. Can i clean the egr or i have to replace them.
Used to own a P10
You can clean the EGR.
cleaning should do the trick. remember to buy a egr valve gasket cuz the old one will break when taking the egr out.
double check the hose between the EGR and the BPT. I think that's what it's called. If that is cracked or leaking you will get a code too.
yep, he is right. the last time i had a check engine light, i had to replace the BPT and some sort of hose at the dealer.
