2002-G-Sport said:
Does anyone no if there is some kind of adjustment for the stock clutch and where it is
I am not too familiar with the P-11's, but read this post:
http://www.g20.net/forum/showthread.php?s=&threadid=206
I am assuming it is not much different than the P-11's. I posted a quick how to on clutch adjustment and also posted the page on www.se-r.net with the procedures.
This should help!
what kind of adjustment are you looking for??? if your clutch feels a bit mushy you can bleed the air out of the system. the clutch bleeder is located slightly right of the distributor. if you're going to bleed them, you might want someone to give you a hand cuz you need someone to pump the clutch pedal.
