You have to remove the air cleaner and all of the plastic intake tubing. As you take all of this off, look down there on top of the transmission, and you should see the cable and a screw on the end which can be adjusted. It is hard to get in there with a wrench to adjust the clutch, but it can be done.
Jerry
He's talking the pedal height and not the clutch cbale itself.... Wish I can help my man, but im lazy and need to do the same. I read something about having to look deep down under the pedal and u will see an adjusting nut or something. Someone chime in.. I wanna do this this weekend as well. :cheese:
