1 - 13 of 13 Posts
Hey guys, I am getting a code 32 on my 95G (OBDII) and cant figure out what this code means. For OBDI, this code is for the EGR crap. Is it the same for OBDII?
Page EC-120 of the 94 FSM
P0400 Exhaust Gas Recirculation Flow Malfunction = Code 32
Well, I just went and checked the vacuum hoses. One going to the EGR valve was not hooked up. I think I need a new hose because it is not going on tight. No biggie, I will get it tomorrow.
Carlos, I do not understand how you are coming up with a misfire code. I checked out the link you sent, but am confused.
I see what your saying Carlos....P0302 Cylinder 2 Misfire Detected
So is that how I should read 3 flashes pause then 2 flashes?
Since I had a hose disconnected on the EGR, should I assume my code was for the EGR?
Where are you reading the codes off of? The ECM? Are you counting flashes of light off the LED?
Discussion Starter #10
Yes, I am counting the flashes off the ECU. 3 red flashes and then 2. It will then repeat this. I guess all I can do is reset it and see if it comes back. The disconnected hose hopefully caused this code.
If you are counting flashes off the ECU I am pretty sure that it is the EGR code after all "32" is "32" not 302. Check out your 96 FSM under section "EC". If I am wrong I would be delighted.
Funny how I am getting the same code as you though.
Discussion Starter #12
Yep, the 95 manual says EGR for code 32. Lets just hope it does not come back now that I have the hose hooked up. I am going to buy a few feet of hose tomorrow and replace it all. I have been HELLA busy with the CRX project. In 2 weeks I have replaced both axles, axle seals, lower ball joints, tie rod ends, front rotors and pads, rear drums and cylinders, and flushed the engine and tranny. I have made a few trips to the junkyard and fixed the drivers window and rear hatch. Its coming along.
Sounds like fun. Let me know on that 32 code, I can't get rid of mine, I really stopped caring about it...unless it fails emissions.
1 - 13 of 13 Posts
