1 - 10 of 10 Posts
Discussion Starter · #7 ·
My starter failed on me last week, so I had a shop replace it. When I got the car back, the Service Engine Soon light was gone (assuming from disconnection of battery). A few days later, it came back on. I'm going to try to change out the thermostat and see if this fixes the problem. So where can I find it?
Discussion Starter · #8 ·
Picked up a thermostat from Infiniti and a new gasket from Advance Auto Parts. Had them doublecheck the code. Got the p1126 again. Also got a P0172 (fuel system rich, bank one). I wonder if this is a separate problem. After I replace the thermostat, I'm going to reset the ecu, and see if it come back.
Any special instructions on how to replace the t-stat? Besides draining the antifreeze? Speaking of which, where is the drain screw? Is it right under the radiator?
drunken master
the little weep hole thingy gets pointed striat up.
Inspect old T stat and let me know if it is not all the way closed.
. it could be coolant sencor is bad. but make your repare and reset it.
the other code may not be related
1 - 10 of 10 Posts
