21 - 26 of 26 Posts
i believe they are 2.75 i will let you know tom., this setup is only for the roller rocker motors will not work on anything else
i am planning of installing a WAI on my P11. but one thing i noticed, on the very first inlet of the stock air filter, there was a small sensor. is this part of the MAF too? should i condemned this sensor when installing a WAI? thanks
um if ur just putting the filter in place of the airbox the sensors just stay where they are and you dont have to worry about them
if you change the whole piping im not sure
on my friends car he just taped them so they wouldnt move around lol
It's measures the air inlet temperature. Some people leave it where it sits because the wires might not be long enough to install it into the end of the WAI's filter, or the filter you have you can't fit it in. Personally, I'd prefer to have it attached to the filter because the ECU uses the temp of the inlet air to adjust itself on a ongoing basis. But that's just me. Really, all you have to do is just lengthen the wires if you want.
It's miles absolutely made for a 00-03 sentra, it bolts right on to the MAF, and works proper the most effective thing is that i've quick ram in now however it comes with the longer pipe to visit the bumper business tips ......Visit the web site click nissan and you may see the 00-03 Sentra GXE not the spec V
21 - 26 of 26 Posts
