I'm tired with people discouraging others with this swap.
I'm currently doing this swap
A p10 is actually easier than a p11 due to it having independent suspension already.
All it takes is a complete gtir rear subframe, holes are already there since nissan made most nissan chassis interchangeable alot. You will need to drill the holes completely through or you can weld in bolts for the subframe to be mounted on
Im actually using an awd k series box with mazworx conversion plate. I have to make some custom mounts, some custom axles and a custom driveshaft
