Hi wondering if anyone has had a coolant hose leak from the stitch seam? This is only from the top short hose. The hose from the thermostat is fine. Is it a bad hose or do I have a pressure problem?
Tire Automotive tire Leg Hood Synthetic rubber
Automotive tire Motor vehicle Gas Automotive wheel system Auto part
1. how old is that hose? 2. you can just take it off and cut off like 1/2 inch and should be able to reinstall. careful about the hose clamp dents. 3. or my preferred method, get a new radiator hose and install. cheap, ez, sure, and done.
I have a G37 with new factory Nissan/Infiniti dealer-bought hoses that do this exact same thing. The old ones did it too and was the reason I replaced them when replacing the radiator. No idea why. Only thing I can think of is silicone hoses may work better than the factory Nissan ones.
