Hi all,
I noticed a coolant leak under my car this morning. It was a medium-sized puddle forming under the passenger side of the car, dripping down the right side of the oil pan/block. I couldn't locate the leak but it looks like it's coming somewhere behind the crank pulley. Checked the reservoir and it's full. Help?
p10 guru
most likely the weep hole on the bottom side of the water pump. use a mirror to verify. if thats the case, you need a water pump
Run & warm the engine up to see if the leak might be coming from a 2 3/4" hose that connect to the intake manifold right below the oil filter.
