1 - 7 of 7 Posts
if you detonate is it possible that the motor suffered no ill effects?
well my brother went to the track and maybe cause it was cold but the boost spiked to 17 and he spun all of second gear bouncing off the rev limiter the whole way till third gear. He said he heard something weird than he lost power in fourth gear. He said the exhaust sounds funny now but the car is still pulling. Would the wiseco pistons have survived that?
oh yes it could survive what happened is he mght of burnt the tip off one of the spark plugs. just check it and see.
You could detonate and be OK, but just remeber it take just one to put a hole on the piston.
trini
well sr20's take detonation well...
unless its a roller rocker like mine and blows up like mine did
anyways, i'd check the plugs first, you'll probably be fine
it is a roller rocker, how did you blow yours up?
overboosting/detonation/leaning out
BUT i didnt have wiseco pistons, only the stock pistons
what engine mgmt were you using?
phew,,,changes the plugs, the metal tips were gone,(the L shaped metal piece). New plugs and wires and she is back to normal...nice!
1 - 7 of 7 Posts
