Need help with this one please!
Car died when I was starting from a stop sign...no advanced warning. I got a P0340 code (camshaft position sensor) which I've erased a couple times but it keeps returning everytime I try to crank the car. Since it stalled out, it has mostly cranked, but not turned over. Mysteriously, a couple times it has run for a few seconds after start up and then it was able to run for a good ten minutes before it stalled out again while I was driving it around the block. I've now been unable to restart it after disconnecting the battery for a while, reconnecting the distributor plugs, checking connections, etc.
I'm thinking about replacing the distributor...it it likely/unlikely that this is my simple problem? Thanks good sirs.
