N
Guest
is there a diff. in advancing timing between above 2000 models and below 2000 models
because i have a 2000 and the pictures in all the different insruction look slightly diff. i seem to have two sensors and i dont know which to take off to do the advancing
does any one know?
I have a 2k G myself and when I advanced the timing I had the same problem, I couldn't figure out which sensor was the right one to take off, so I didn't take any of them off. I know everyone says "make sure you disconnect the tps" well I didn't and it's been over three month's and it is still at 19 deg. I did follow all the other parts of the rain dance I just didn't mess with the tps. So some people will probably come on here and say "Oh he is full of it and he probably did it wrong." But like I said I did it, I noticed a difference and I have checked it after nearly three month's and it is still set right where I want it.
It's the brown one on top. That's the TPS connector. :cool:
