1 - 20 of 22 Posts
I have a 7 dollar timing light which works wonderfully.
What are you all doing to ensure that you are setting your rpm right?
Do you use the factory gauge and call it a day?
Thanks
Several have said the tach on the car is not accurate at all. You can get a tach gauge for 10-15 bucks at pepboys I think. The other option is to get a timing gun with a tach built in, but they are about 100 bucks.
Thanks. I mean is it a tach thats just used for troubleshooting? Does the tach get removed when done? I don't want to leave it in the car all the time.
you all have my attention...I would really like to connect an accurate tach though since I have a working timing light, and wish to conserve $$...
Used to own a P10
now thats a good deal...
not sure if it will work on my 94, I guess it would?
wondering about the software and where I'd get it though...
Does the camsult software work with that cable?
Used to own a P10
The 94 is OBDII so I'm not sure if they use the same Consult port. If it does, that CalumSult software is available from this website:
http://web.utk.edu/~cjohns32/calumsult/
There's also another package called TECU that allows you to do timing, A/F, and IAC adjustment on the fly, as well as turn off individual injectors and the fuel pump. It's free too. Sweet!
Discussion Starter #11
hmmm I wonder to, thanks for the input, maybe someone with a 94-96 will chime in
Discussion Starter #12
bump
Discussion Starter #13
anyone know why a laser photo tach won't work? they are even cheaper
Discussion Starter #14
oh well, I just bought an inductive timing light and a VOM with the tach feature, what a difference!
I know you have this problem solved already but I figure I'd chime in anyway.
The consult port is the same from obdI-obdII. I used the same style interface box and calumsult on my 95 obdII p10 and my friends 91 obdI b13 this weekend with no problems.
Mike
Discussion Starter #17
Mike
Thanks for all this. BTW, you are right on the tach. Wish I didn't waste my money to determine its accuracy.
Oh well, I can use it on my beater car now.
Used to own a P10
Which one did you buy before ??
I couldn't use that one with my carpc as it's too bulky and I couldn't leave it plugged in.
Used to own a P10
1 - 20 of 22 Posts
