sometimes when I'm at idle or in park (auto tranny), the dome light rattles quite a bit. I took out the bulb but it still does it.
the clear plastic cover is cracked in half but it was a clean crack and I could snap it back into place and have the force hold the 2 halves together. But even before it cracked it still rattled.
I have a 94 BTW.
pull off the covers and check the screws holding it up, they may be loose, tighten them up. If that doesnt solve it, just take the screws out and pull the lamp down and see whats making that damn noise.
will do! I have a few squares of dynamat extreme left over so If it's easy to get down I'll put some dynamat under it. I don't have to take off the whole headliner to get to the bare metal right? Just remove some screws?
