Hey, i'm changing my driver side door and need to change the key lock thing so i can use my key, i'm wondering if anyone knows how to change this, i can't figure it out.
You need to remove the inner trim panel and get access to the key cylinder from the inside. Once you've gained access, there should be a 'U' shaped retaining clip that holds it in place. There will also be some sort of plastic retaining clip connected to the 'Key Cylinder Rod'. You need to carefully remove that from the rod. Once you've done that on both doors, you can easily swap the key cylinders.
Beat me to it. There is some discussion of it here as well:
http://www.g20.net/forum/showthread.php?t=33087
