1 - 20 of 21 Posts
As title says... in the dash the brake light stays on.
It happened like a week ago, but after I drove for a little while it came off. This morning it didn't. I left work and it stayed on the whole time. The ABS works (as I was driving on ice), and the ABS light is not on. The ebrake is not engaged, but the light stays on.
Does it have to do anything with the cold???
All my searching returned either ABS questions, or brake lights that stay on, but nothing about the dash ebrake light.
It's annoying... any ideas?
Demon
p10 guru
check your brake fluid and brake pads. if the fluid is low the light will come on. if the fluid is low without any leaks, it is probably due to the pads wearing down
Discussion Starter · #7 ·
Thanks all...
I would have checked somewhere in the rear tires first, not knowing what to look for.
Indeed, the fluid reservoir is low. The problem is that the tube is pretty wet on the outside, leading me to believe there is a leak somewhere. I will have to pay a mechanic sometime to fix it.
For now I'll just keep adding brake fluid.
:baffled:
Demon
My ebrake light is on because I need a new ebrake switch in the middle console. When I move the ebrake lever up and down slightly I can make the light go off and on. Does your light turn off at all by moving the lever?
Discussion Starter · #10 ·
markbuts3 said:
I dunno about on US P10's but on mine I can tell whether it is the fluid or switch that's causing it because the fluid will only cause one light to come on whereas the fluid will turn both lights on.
Huh??? "the fluid will only cause one light to come on whereas the fluid will turn both lights on?"
Anyway,
I"m pretty sure it's the fluid, as it is clearly leaking. I've never had any problems with the handbrake, and there is just no way to make it turn on or off with the lever/switch. I tried quite a bit.
I will let you know tomorrow once I have the chance to buy some fluid.
Demon
Discussion Starter · #12 ·
Yes, congrats BTW. I was actually surprised that you replied. I thought you wouldn't be leaving the hospital. Maybe you have a laptop there? :p
Anyway, I added brake fluid and it went away. Now i just gotta find out how long it will last this way.
Demon
check to make sure your calipers aren't leaking, most likely you have a leak in your cylinder. I had that, ended up replacing them. Just look underneath see if there's oil in the inside of your wheel...
Demon
I'm there from about 10am after I've taken Jake to school and then come back to pick him up and head back there, after feeding him, until about 8pm.
I'm having the same problem with my dash brake light. The red brake light in my dash has been on since november. It goes off rarely when I'm braking, but it never stays off for more than a few seconds. I checked the fluid, and it's right where it should be. So I checked out the handle itself, and there was a AAA battery lodged under it, keeping it from going down all the way. I was able to get the battery out with my trusty extendo-magnet, and the handle now goes all the way back down, but the light still doesn't go off. So is it most likely just that the pads need replacing or the float in the brake fluid reservoir? I was planning on changing my pads in the next week, but just in case, where is the float and what does it look like so I can check that out?
i thought i had this same problem the other day... but a water bottle cap had fallen beneath the switch keeping the light on when the lever was down. :zoinks:
the light has nothing to do with the brake system, is your switch in the middle of the console that gets stuck, I'm having the same prob on my P10.
Rob
Rob
if your low on fluid, the brake light will illuminate, so i would say it has a lot to do with the brake system
La-illaha Il-lallah
Rob
Not true. I had the light come on when my brakes became really worn. I added fluid (not a smart thing - change the pads instead) and the light is gone and has not come back. When I replace the pads I should have a mess of fluid come out the reservoir.
1 - 20 of 21 Posts
