1 - 15 of 15 Posts
6'5 290lbs in a G20 said:
Is this a good combo with the KYB drop shocks ?
Is the handling any better ?
Does the car even look lowered ?
I've got a 40mm drop with mine and the ride is very firm....Too firm when going over bumps etc.
But handling in corners is great.
It does give the car a nice lowered look though.
304border said:
Hey man go for KGMM spring they are the best spring for sure but they only have 1.8 and 2.2 so
Are those the drops? The 2.2 is WAY to low for stock length shocks. You'd need to get some shortened shock bodies with those. The 1.8 are marginal but you can get away with stock length shocks. I'd still get shortened shock bodies.
Unfortunatly there are none on the market at the time, so don't ask. :(
What about Motivational Engineering? I know they did shortened struts for Sentras.
You're right. They *did*. Last I heard they were going to stop making shortened struts for the Sentra. :-\ I could be wrong however. There was a plan to make G20 shocks the last time I called him, buuuuuut....never heard about it again. :(
1 - 15 of 15 Posts
