I'll add more later. Dane is impatient so I'll post what I have so far.
This mod is for adding 1157 dual filament bulbs to your P10.
Normally the p10 uses 1156 27 watt single filament bulbs, and they flash when use your turn signal. The 1157 bulb has two filaments; one is 8 watts, the other 27 watts. This mod allows your corner lamp to dimly light up by using the 8w filament, and also still use the 27w filament for your turn signal. The 1157 uses a different socket and wiring so you will need to source this. Most commonly it can be found on the B13 sentra, but other nissans and subarus have them as well.
You need this, one for each side. B13 corner lamp socket, orange bulb, and the wiring that goes with it.
The socket has 3 wire. Ground for both bulbs, and positive for each filament.
The socket has 4 tabs instead of 3. You need to cut off one of the tabs.
It will now look like this. I just used my pocket knife. Any sharp knife will cut right through it.
Here the bulb is reinstalled.
Socket now fits in the back of the corner
Here is the stock wiring left over. I'm going to reuse this so I don't cut any harnesses.
I don't have bumper lamps because I have primera bumpers. So I took the harness that goes to that bulb and re routed it to the corner lamp. One is turn signal, the other is the bumper clearance lamp
Here is a diagram. I added my side markers into this too but I left it out for simplicity.
