the other day, i was sitting in my car, cleaning the windows, and I had my radio going. I open the sunroof.. and I noticed, whenver the sunroof motor was going, the two front speakers would quiet down or completely cut out. Should I be worried about that?
G20 Junkee
ok
Let me guess. Do you have an aftermarket sound system? If so was it professionally installed?
If it was take it back!
If you did a shadyTREE then here's ur problem. You have a bad ground. Either a faulty or loose wire or a poor connection with the deck or the speakers. Check them again.
hope this helps. This was yet another $0.02 from your friendly Eskimo, Now back to the Igloo i go
Re: ok
Nope... the system is bone stock...
G20 Junkee
I still believe that there is a bad ground somewhere. U might have to take it to a liscensed mechanic unless u know how to use a voltmeter?
