PDX-G20 said:
what will more easily pass emissions, a det or de-t ?
I know compression has some effect on emissions, but I think if you include EGR with either set-up it shouldn't be a problem.
If you have a cat and are operating in closed loop (with an operational O2 sensor), you should be fine regardless. New plugs and Mobil 1 help, and you need to get the engine to full operating temp before the test.
Ignition problems will lead to high unburned hydrocarbons, while a rich condition will increase carbon monoxide.
I had an old Ranger with the Cologne V6 that didn't have factory EGR. It passed emissions with more than 100k miles and a gutted cat.
Higher compression increases oxides of nitrogen - no big deal if you're not borderline to begin with.
Good luck
