today, while getting out of a parking spot, the engine just died. i turned off the car and then restarted it. it worked again. the car itself was very shaky maybe because of motor mounts. i have no idea wuts the problem. will the fuel filter have to do with anything because it seems very old. i am clueless. still trying to learn basic car things.
a lot of our g20's stall when you switch in and out of a gear, although the shakiness is a little out of place. My car sometimes stalls when I go from drive to reverse. But a tune up would be a great idea a def. change the fuel filter too, it only takes 2 mins.
tune up fule filter air filter injection clean do what you can and it will run better also check certain sensors like the maf and o2 sensors they can make it run lean thus stalling.
