My P10 (95) has 110K miles on it. When I do a hard acceleration (1st or 2nd gear), around 2-3K rpm, I hear engine knocking. After it passes those rpm everything normal. I didn't notice this knocking during 3d or 4th gears.
Can you tell me what is the problem and how can I fix it.
I only notice on 1st and 2nd gears only. I may not noticed higher gears beacasue of the wind/tire noises.
You need to check your ignition timing. If you are running 87 octane gas, then set the timing to 15 degrees BTDC.
it maybe your rod bearings are going out. That happend to mine so I toar off the oil pan and discovered metal shavings. Luckly I caught it in time and was able to replace the bearings without messing up the crank.
