1 - 14 of 14 Posts
Recently my 1999 G20 had started making a metalic grinding noise coming from under the VC. I took it to the mechanic (Infiniti Dealership) and they said that it is normal for a SR20DE to make that kind of noise when it has 80k+ miles... *sniff* *sniff* Smells like bullshit *sniff* *sniff*.
The noise sounds like scraping a metal pipe on cement.
Oh --- -but they sure did find lots of other stuff wrong!
Starter needs replacing
AC Compressor needs replacing
Transmition might need replacing
.... More....
What is this engine noise - I really need info on this ASAP. Thanks
Check if you have a OEM Nissan filter on it. In the next oil change use 10w30 if it doesn't helps then you'll need to change the chain guides and tensioner *19 and 20*
yea if it sounds like metallica chatter it could be the upper chain guide. mine makes a bit of noise but not too bad.
this should be a sticky. i know my alternator bearing is dieing too so i so a supercharger type sound but this is another noise i might have to diagnose later.
Where can I buy a new tensioner, the bolt.. mine snapped. :(
wtf! what was wrong?
Discussion Starter #11
New Starter
New Compressor for AC (+ something else for AC)
They did something with the Transmition and changed fluid
Fixed the noise from under the VC.
I'm not really sure what all they did - I'll go check the recipt later.
Either way - good as new :)
$1800.00 :angry: thats the price of a det :asian:
1 - 14 of 14 Posts
