allright, i posted something about this a while ago but i wanted to let everyone know exactly what the problem is and what i should check...
My car will idle fine for a second and then the rpms drop to around 200 and it struggles to maintain and then it dies... what i've found out is that it only does this on really hot days and my car doesn't even have to be warmed up for it to happen.
today i turned my car on for maybe 3 minutes, turned it off for another 3 or 4 and tried to turn it on and it died and it was 94 today.
anyone know what this could be?? i've never heard of anything like this before... thanks
Go to www.se-r.net and follow all of the maintenance, problem fixes, and procedures. This would include:
1. BPT/EGR valve clogged
2. MAF reground
3. Plugs, wires, cap & rotor
4. base idle is wrong
5. timing is wrong
6. throttle body is dirty and needs cleaned out
Almost gaurantee you will find the problem following all of that.
thanks man, i'll check everything out.
