SR20VE and VQ35DE
neither of which are plug n play. Search up on those two.
So SR20VE and VQ35DE will not be a plug and play? If that's the case I wouldn't want to do a swap with those engine's.SR20VE and VQ35DE
Damn, gonna have to stick with the stocker then.the only plug and play engine for your car is the engine that it came with.
He is talking about getting a different engine.VE Cheaper than a stock RR?
even if you can get the VE at a cheaper price...it would cost more to make it work in a 00+
Thanks brother, just outta curiosity that VE(I believe your talking about SR20VE engine) swap would be cheaper, what model should I get? Well I mean year, is there a ot I would have to do as it's not a "plug and play"?I seen your post about burning oil. I say ride this one for awhile and save your pennies. Except for what you spend on adding oil. By the time you get totally sick of adding oil or you just happen to forget, you will have enough for a swap. I do believe the VE would be the cheapest route.
