1 - 20 of 48 Posts
Ok guys, here it is:
The next 25 orders will get an Infiniti or NISMO hat (your choice) for $0.01 (sorry, can't make it $0.00 and still have it work properly in our systems) with any purchase over $25.
AND
All orders for the rest of the month will receive an additional 5% off. The 5% will apply to ALL parts (yes, including aftermarket) and not just a single "special" part or kit.
This is valid for online orders only, through the end of the month.
During checkout, use the coupon code " November " to receive the extra 5% off.
To add the hat to your order please add the following part to your shopping cart and select the desired style.
Infiniti/NISMO Hat
Also, I added a few things to the catalog, so they'll be easier to find:
Front Motor Mount
Rear Crossmember Mount
Transmission Mount
Front Crossmember Mount
In-Cabin Microfilter
junknstuff said:
"That coupon code has already been used by you on a different order!"
when trying the November code
and also, prices listed in the link isnt what is showing up in the shopping cart :nervous: just trying to help out :smile:
*edit* nvm about the price difference, i noticed its more $$ for the p10 mounts :surprised
Try it again... I've changed it so you can use it multiple times per account.
Justin should I cancel and redo an order I just placed so that I can get the 5% off? Or can you take care of that?
how much is a set of Tan P10 floor mats?
P10 FTMFW!!!
Damn i have to wait to order my parts till tomorrow :(
Think so Junkn'stuff?
let me know how that ride is when you fill em.
I'm pretty picky but I'm getting tired of the ol' SR sloshing around the bay.
Question...
I don't want to sound greedy but...
Would the 5% apply to the deal on the $850 Tein's + would I also get the Nismo hat?
no rainguard clips...FML
i would say so ;)
walrusx4
i read it on a thread here somewhere but im sure it'll be fine. i think it was something like the motor moves back and forth more then side to side so thats why.... :knockout:
Discussion Starter #16
IONO_Anything said:
Question...
No, all the prices in that other post do not apply. The savings are a lot better than 5%. $900 - 5% = $855 + shipping.
rmyc said:
much for these for a 94 g20 5pd non-LSD:
Bearing clips x2
Axle seal (drivers side)
Axle seal (passenger side)
Circular clip, aka “Ring Snap” (for the transaxle end of the driver-side)
$4.15ea
$6.94
$6.51
$0.71 (special order)
http://www.infinitipartsusa.com/G20accessoriesP10.html
$103.05
junknstuff said:
order placed....
as i read correctly, it would still be a smooth enough ride by filling in the crossmember mounts but running oem mounts for the other two right...
Yeah, normally the side ones are the ones that transmit the most vibrations into the car. Filling the two on the crossmember, but leaving the other two stock should give you the best support with the least amount of vibrations inside the car.
Discussion Starter #17
Hey guys, sorry if there's some confusion.
It's one hat per order, not one hat per $25 spent.
1 - 20 of 48 Posts
