1 - 13 of 13 Posts
The weather was exceptionally nice here in Chicago, I'd figure it's about time I gave the G20 a wash. Enjoy the photos!
I used my Nikon D90 18-135mm CP Filter [quoted at 35mm equiv]
1.
72mm f/4.8 1/50s ISO400
2.
27mm f/3.5 1/40s ISO400
3.
27mm f/4.5 1/60s ISO1600
4.
33mm f/4.5 1/60s ISO1600
5.
27mm f/3.5 1/80s ISO1600
6.
51mm f/4.2 1/40s ISO1600
BankBen
I've updated the photos... they should work now. If the weather stays nice i'm thinking i ought to paint the valve cover.
you can maybe do that on tuesday..
you should really have at least 65 degrees for the paint to adhere properly
Dude, your bed is a car..
drop it like is hot! :smile:
Thanks for the tip Chris, I haven't really considered the temperature needed for the paint to cure. BTW: the wheel and tire set has been fantastic, again thanks for the hookup.
I'd like to drop the car a few inches, but with only 74,000 on the ODO I can't really justify the cost right now. Maybe in a few years ill go for coilovers! Then again... perhaps Chicago winters aren't conducive to dropped cars...
Discussion Starter #12 (Edited)
Beautiful time of day to shoot, the lighting is great.
Thanks, zac3ne2nr! Initially I wasn't planning on taking pictures, however after I washed the car I noticed how the sunset reflected off the deck in the first picture... I was loosing light quick, but i enough time to bring out the ladder for some different angles:teeth:
1 - 13 of 13 Posts
