1 - 20 of 21 Posts
Is there a demand for these, even if they're the same price or slightly more expensive than a JWT flywheel?
P10 WRC said:
i think if you can verify that they wont throw a code, there might be
The new fidanza should not throw a code. The JWT definitely will not because it uses a factory ring gear on the flywheel.
But would you spend as much or more on a Fidanza, just because of the name? Or would you rather get the nice JWT unit for an equal or lesser price.
drunken master
my old fidansa trew the crank sencor lack of cog code. It also cracked at the contact point. Can you blam it though? I right now have a stocker given to me and i feel a big diferents in the 2 as far as just driveing. I hve not rn the new unit at all but i have had fun with mine till it kicked the curb
I dont think the friction pads are that much, i think they are in the $75 range. if you use a regular organic clutch and a good quality pressure plate, it should last you a long time. if you use a 6 puck and extreme pressure plate that holds 500-600hp it will wear the ring down faster.
p10 guru
for those of you that installed the fidanza on an obd2 car.... which part # flywheel did you install? was it the one listed for the b15 sentra?
1 - 20 of 21 Posts
