Hi people!
I was searching the forums but I couldn't find an answer...
My driver's side fog light (P11) has taken in moisture somehow, causing some "dew-like" water droplets on the inside. I know that the fog light housing may be broken or cracked somewhere but I was unable to find anything pointing to it.
The transparent cover is tight as it should be and the back of the fog light does not have any visible crack.
The rubber seal/o-ring that sets on the bulb cover on the back is in good condition (looks new) and the cap that screws to it is not broken.
I have not hit anything with that side that I remember.
There is also a rubber "u-piece/tube" that seems to be a breather of some kind on the back of the fog light. Am I correct on this?
Can the moisture be entering somehow through that "breather"? (I do not think so because the other fog light is ok)
Has this happened before to anyone?
What would be the best possible way to tell what's wrong with it before I spend some $$$ on a replacement? With all that moisture that fog light just looks plain awful.
Thanks in advance for your help.
Robert
Robert
