1 - 2 of 2 Posts
no rainguard clips...FML
the thing with p10s is that we're already wired up for foglights, you just have to source the oem switch and actual foglights and youre good to go.
another good thing about this is that if you dont want to use OEM ones (like what youre doing) you can still use the wiring supplied as well as the oem switch and just splice the wires into your aftermarket foglights. i've seen it done, and apparently its been done to my car so you should have no troubles
1 - 2 of 2 Posts
