P10 REAR brake caliper adapters for use with Z31 11.4" (290mm) rotors, this kits allows you to retain your stock caliper and pad and stock e-brake cables, true bolt-on affair
Special note: You will reuse your stock caliper mounting bolts one of them you will not run a washer on this is for clearance purposes
Price $179.99
For visual refference on my P11 the rears are Z31 11.4" (290mm) rotors bolted on with my brackets which I now make for the P10......fronts are A34 Maxima 12.6" (320mm)....wheels are factory G35c 17's
