1 - 20 of 26 Posts
New UNISA JECS Polyurethane crossmember engine mounts for P11 (or rear mount only for P10)
Replace your stock crossmember engine mounts with these 85a durometer polyurethane mounts to eliminate front to back engine movement from aggressive shifting and increased engine power output from turbocharging or NA mods.
$100 for each crossmember engine mount + $16 shipping
Discussion Starter · #2 ·
Still got these available $150 for a set of P11 crossmember engine mount plus $25 core per mount.
do you have any options for the passenger side mount.
No sir I never seen a reason to make that mount I keep that one stock all it does is add a lot more vibration into the cabin without doing much at all in the way of keeping engine movement down compared to the crossmember engine mounts and that's my honest opinion and I get out there and beat on my car every chance I get, I don't like rattles and vibrations inside my cabin unnecessarily I try and keep that down to a minimum so that's where i'm coming from.
Discussion Starter · #13 ·
how much do these increase NVH my mounts are bad rn, looking to replace, but dont want to deal with annoying vibrations
Not much at all its only really noticeable at start up and idle but its not that bad at all IMO, anyone that has ever rode in my P11 can attest to that and I have a lot more parts on my P11 such as crossmember bushings and subframe inserts and my lower control arms.
Discussion Starter · #14 ·
Christian your crossmember engine mounts along with the rest of the parts you purchased are on the way, thank you
Charlie, any idea if these are more or less stiff than Prothanes?
My rear Prothane on my P11 has oval'd out and needs to be replaced. Was just going to get another Prothane to swap it out, but I might be interested in trying your mount out. LMK when you can!
Branden
aka hawaiiaNX
Discussion Starter · #18 ·
Branden
aka hawaiiaNX
I can probably do for you what I been doing for the B-Chassis guys so you dont have to buy a new prothane mount and the probably just repeat itself and make you a larger sleeve here is a picture from Pat Klutch and a stock B chassis rear prothane mount...
What your looking at here is a new larger sleeve pressed into a prothance rear B chassis mount and also a side by side comparison of the larger sleeve vs the stock prothane sleeve there is a big difference, this will basically rejuvenate your oblong mount and put back the preload if you will back into it which it should have had much more of from the start. You cannot compare B-chassis vs P-chassis they both start off with different size sleeves and the P-chassis stock prothane sleeve is basically the size of the upgraded B-chassis so the P-chassis will be even larger, i'll send you a pm
1 - 20 of 26 Posts
