1 - 20 of 68 Posts
I have a 5 lug conversion swap for sale:
$350 + $25 ABS ring cores + shipping
Includes:
x2 NEW front hubs w/bearings and seals
x2 NEW rear hubs w/bearing (as of 2/2/2015)
x4 Seals
x2 P10 or P11 ABS rings modified and fitted onto rear 5 lug hubs
x2 P10 or P11 rear spacers and/or sleeves
Oooh, so tempting.. What oem BBK for under 400?
You could go with A34 Maxima 12.6" front (requires you to drill out the front spindle holes) and either A33 maxima rear torque member brakcets with 10.98" or like I did and used Z31 11.4" rears with my brackets and the stock P11 torque member brackets.
Discussion Starter #8
I don't know exactly. I'm about allegy. though should be able to work on it after getting better. :zoinks:
I'm sure to send you p11-abs rings once jobs done.
Ok sounds good.
what front hubs do you use. Also is it pretty simple to install fronts i have your kit that i bought off of kidcaffeine.
Damn that's old lol, 89-94 maxima front hubs are what is used, its not to hard but you need a press.
Discussion Starter #10
Good advice for those Diy'er types and best take a micrometer to the yard with you also cause the difference between a good and bad hub is less then the thickness of a single strand of hair on your head just fyi
The figure it out guy...
FYI, Do not use front hub of Maxima SE 92-94 liked me did
HAHA it has 29 teeth. our p11 or p10 has 27 teeth
It is 89-94... just 92-94 had a motor option which also changes axle and hubs... must be small 4 banger FYI ;)
:hurt: I was just heading to Maxima year range 89-94 in local yard, with careless and unplain I took a crap parts for 1-1/2 hrs on SE'93.
Its a SOHC vs DOHC thing...
You already let me have a SOHC, thanks
1 - 20 of 68 Posts
