this question might have come up before, and YES i already did the search, but didnt find anything about it... so yah. I have a 2002 G20, and it claims that the fuel tank capacity is 15.9 gallons. Even if i let my gas go down to empty, I still only put in like 12 or a lil more gallons. Is sumthin up with that? Or do our cars have like 3 gallons of reserve gas after it hits the red line? This is all after gas light goes on too. I dont usually run it that low all the time, but i was trying to test it out.
I believe every car has some reserve capacity built in from the factory. I think I might have filled up the tank with 13.xx gallons maybe once or twice in the past 4 years. Most of the time it's between 10-12 gallons even when below the 1/4 mark. What you describe sounds normal. I actually think I remember reading on the SE-R list a while back that the cars won't start without something like 2 gallons of gas or so, but i'm not 100% sure on that, you'd want to double check that just to make sure.
i have gotten my tank down to .5 gallons before. it started fine, but was real sluggist. jerked around alot. wouldnt recomend it, but i did it b/c my paycheck came in late and i had no money. oh and the needle was like resting, of course.
well if you really want to find out....run out of gas, then filler back up....let us know what you find out.
i think the gauge on our cars sucks. i drove 120 miles on empty a couple days ago and it only filled up 12.5 gallons. the other thing that pisses me off is when the pump shuts off automatically it reads only a little over 3/4 full. i usually top it off another half or 3/4 gallon to make it read full.
