So here is the story..
Car had been sitting for about a month because the radiator support had completely rusted off. I finally got that fixed and was excited to start driving it again. Then my starter goes out so I replace that. Finally, I turn it on, everything is great and I drive off. On my way back from the mall I notice the RPMs begin to get a little too low and the car begins to shake. I arrive at a red light and they drop below 500 and car shuts off. I manage to start it again and keep it on by giving it some gas. Eventually make it home trying my hardest not to time my stops at red lights so it wont shut off again.
I had some pre-exisiting codes so I cleared them using the OBDII reader. I took out the MAF and sprayed it with Choke/Carb Cleaner..(not sure if this was a good move), I cleaned the air filter and put it all back together. I start it and it works ok for a little while. In fact I started it 10 mins ago and let it warm up..but once I moved it about a block it started dropping RMS again. They get so low that eventually the car just shuts off. After this, I try starting it again but as soon as it starts the RPMS drop all the way down. I make it back home by giving it some gas (to prevent it from stalling).
Any ideas? I haven't driven it much since I cleared the codes but no Service light yet... MAF?
