Hi,
i want to swap an gtir engine to my p10, but i m worried about the gearbox
if it can handel the power and if not what gearbox can do?
thanks for advice
RWD swap. TH400 with the 350 valve body. Trans brake. 4.10 rear diff. A Dana of course. And the rear end from the biggest Ford truck you can find. Hoosier slicks.
well thats not the answer i wanted, and not Something i will do
those people ho have an det in the primera run stock gearbox?
Yes. 32 a/v.70 a/v. Plenty people done it reliably for years. Shift kit the auto with a huge cooler, but if your not great with tranny's (??) Go with the stick. Plenty of build threads. Should be good up to 350 stock gears.
Ok, so will test with my stock manual gear box and see how long it will last
Thanks
