1 - 18 of 18 Posts
:p Hey all, the G-ride is about to hit 60k and its ready for a tune up. I'm wondering if anyone has any extra tune up tips that you have done to your ride to keep it going on strong.
I've planned on doing some of the easy stuff at home, what do you recommend that I get taken care of at the shop?
Also, any tips on parts (type spark plugs, wires, etc) would be helpful too.
Thanks ;)
NGK Platinum
As far as spark plugs go, only use NGK platinums. I believe the one you need for a '99 is the PFR5G-11. NGK lists the PFR5B-11 for earlier model years, but I'm not sure what the difference is. Anyone know? The point is, your engine will hate you if you don't use NGK platinum plugs! :eek:
I thought all SR20's oem platinum plugs were the PFR6B-11. Nissan released a TSB many years ago that stated the PFR5B-11 was to be replaced with the '6' heat range instead due to driveability problems or something like that.
Also, NGK supposedly changed the model number from PFR6B-11 to PFR6G-11, and I have been told they are the same exact plug. Anyone else no any difference?
Regular tune-up would be air filter or clean cone filter, plugs, wire, cap & rotor, clean throttle body then re-check base idle and timing, check your belts, anti-freeze, brake fluid, power steering fluid. And that's about it.
Use OEM Nissan/Infiniti wires, cap & rotor, and oil filter as well. Your car will love you for it.
You might want to add transmission fluid to that list of things to replace. It depends on its condition, so make sure is clear red. If it's turning brown or getting cloudy you may want to consider changing it while you're doing the rest of that stuff. It's pretty easy; kinda like changing oil.
Mobil 1 Synthetic motor oil and ATF. These two are a must.
Here's a list parts for the P10 model some fit the P11.
Infiniti part# 1120-64J06 P10 A/T Motor Mount
Infiniti part# 1121-62J15 P10 A/T Motor Mount
Infiniti part# 11320-64J20 P10 A/T Motor Mount
Infiniti part# 14710-78J01 P10 EGR Valve Assy
Infiniti part# 14741-02E00 P10 BPT Valve
Infiniti part# 22670-78J00 P10 Fuel Pressure Regulator
Infiniti part# 14956-38U10 P10 P10 EGR Solenoid Valve Assy
Infiniti part# 80606-4B704 P10 Frt Door Outr Rh Assy Blk
Infiniti part# 80607-4B704 P10 Handle Assy Fron
Infiniti part# 2240-0M811 P10 Plug Wires
Infiniti part# 22401-1P115 P10 NGK Platinum Spark Plug
Infiniti part# 22162-3S505 P10 Plug Wire Cap
Infiniti part# 22157-46N12 P10 Cap Rotor
Infiniti part# 16400-0M200 P10 Fuel Filter
Infiniti part# 11920-5U011 P10 AC Belt
Infiniti part# 11950-53J20 P10 Pwr Steering Belt
Infiniti part# 999MP-A4025 P10 Weather Strip Cement
Bosch part# 61075 P10 Fuel Pump
Infiniti part# 17342-79900 P10 Packing Fuel Gasket (used w/Fuel Pump)
Bosch part# 13039 P10 Oxygen Sensor
NGK part# NX11-9886 P10 Plug Wires
NTK part# 24075 P10 Oxygen Sensor (Catalytic Converter)
K&N part# HP-1003 P10 Fuel Filter
Infiniti part# 28156-67F10 P10 Rear Speakers
G20 P10 Part Numbers!!!!!!!!!!!
95 P10 owners, Here you go enjoy!
OK! and here are some more.
Infiniti part# 13270-53J05 - Valve Cover Gasket -
Infiniti part# 23100-0M810R - Alternator -
Infiniti part# 17251-79912 - Fuel Tank Cap -
Infiniti part# 23300-63J10R - Starter Motor -
Infiniti part# 16400-0M200 - Fuel Filter -
Infiniti part# 46010-62J72 - Brake Master Cylinder -
Infiniti part# 40206-71E06 - Front Brake Disc -
Infiniti part# 43206-42R05 - Rear Brake Disc -
Infiniti part# 41060-6J090 - Front Brake Pad Kit -
Infiniti part# 21503-53J00 - Lower Radiator Hose -
Infiniti part# 44060-6E390 - Rear Brake Pad Kit -
Infiniti part# 21430-4B700 - Radiator Cap -
Infiniti part# 21200-53J00 - Thermostat -
Infiniti part# 21501-53J00 - Upper Radiator Hose -
Infiniti part# 21010-53J01 - Water Pump -
Infiniti part# 46010-1N420 - Brake Master Cylinder -
Infiniti part# 40206-7J101 - Front Brake Disc -
Infiniti part# 41060-0V090 - Front Brake Pad Kit -
Infiniti part# 43206-9E601 - Rear Brake Disc -
Infiniti part# 44060-7E690 - Rear Brake Pad Kit -
The last five part numbers are p11 brakes, stock upgrade for the P10
so the boche platinum that has four of those little things at the tip is bad? i should take it out and put NGK in em?
Yes, those have been affectionately called "Motor Killers"... use all stock ignition components. Best prices I have seen are are Infinitipartsusa and Infinitiparts.net.
Don't forget the fuel filter!
Infinti g20 sparkplug info
Sparkplug INFOS based on INFINITI MANUAL
P10 - 1996
PFR5B-11, XFR5A-11 (no need to gap) ,BKR5E (0.031in to 0.035in \ 0.8mm to 0.9mm gap size) ,HOT
PFR6B-11, XFR6A-11 (no need to gap) ,BKR6E (0.031in to 0.035in \ 0.8mm to 0.9mm gap size) ,Standard ( FACTORY )
PFR7B-11, XFR7A-11 (no need to gap) ,BKR7E (0.031in to 0.035in \ 0.8mm to 0.9mm gap size) ,COLD
P11 - 1999
PFR5B-11 (no need to gap) ,NO RECOMMENDATIONS ,Standard ( FACTORY )
PFR6B-11 (no need to gap) ,NO RECOMMENDATIONS ,COLD
PFR7B-11 (no need to gap) ,NO RECOMMENDATIONS ,COLD
P11 - 2000
PFR5G-11 (0.043in \ 1.1mm gap size) ,BKR6E (0.031in to 0.035in \ 0.8mm to 0.9mm gap size) ,Standard ( FACTORY )
PFR6G-11 (0.043in \ 1.1mm gap size) ,BKR5E (0.031in to 0.035in \ 0.8mm to 0.9mm gap size)
PFR7G-11 (0.043in \ 1.1mm gap size) ,BKR7E (0.031in to 0.035in \ 0.8mm to 0.9mm gap size) ,COLD
P11 - 2001
PFR5G-11 (0.043in \ 1.1mm gap size) ,BKR5E (0.031in to 0.035in \ 0.8mm to 0.9mm gap size) ,Standard ( FACTORY )
PFR6G-11 (0.043in \ 1.1mm gap size) ,BKR6E (0.031in to 0.035in \ 0.8mm to 0.9mm gap size) ,COLD
P11 - 2002
PFR5G-11 (0.043in \ 1.1mm gap size) BKR5E (0.031in to 0.035in \ 0.8mm to 0.9mm gap size) ,Standard ( FACTORY )
PFR6G-11 (0.043in \ 1.1mm gap size) BKR6E (0.031in to 0.035in \ 0.8mm to 0.9mm gap size) ,COLD
PFR7G-11 (0.043in \ 1.1mm gap size) BKR7E (0.031in to 0.035in \ 0.8mm to 0.9mm gap size) ,COLD
Standard sparkplug replacment for Platinums: 105,000 miles
All of these plugs are NGK this is what Nissan used as their OEM sparkplugs.
hey guys...
I'm willing to create a document only for "General Tune-UP MAINTENANCE" say an ALL-IN-ONE .pdf document that will cover both P10 & P11 series (US version)
I will post them here so everyone can download...
This will be our P10-P11 TUNE-UP BIBLE.
All recommendations like BEST OIL FOR SR20DE, Torque specs ( wheels lug nuts, sparkplugs etc. ), Nissan OEM preventive maintenance part numbers and third party part numbers., when to rotate wheels, cabin filters.....wiper fluids...
What I am saying is it's a General TUNE-UP BIBLE... ( it's NOT a document on how to FIX broken stuff )
Ofcourse I still need your assistance proof-reading the document then if everything is accurate then we will post it here. The document will be based on the FSM and inputs from all of you.
so that simple questions like "what's the best oil for my G?" or what's the best 3rd party Sparkplug wires? questions like that we can always refer them to our TUNE-UP BIBLE.
What do you guys think?
Best oil...well oil is one of those things that people are going to continuously argue over. MY opinion, 5w-30 doesn't matter what brand as long as you change it.
Spark plug wires...buy OEM. not OEM style, or OEM equivalent from the parts store..actual OEM parts from the infinifi or nissan dealer. They will probably be made by sumitomo or yazaki but they will come in a Nissan package so you know it is good.
Ok Bros...
Together with the FSM infos what infos you guys want to include?
Say alternative 3rd party parts?
Cheaper but better than NISSAN OEMs maybe?
Parts to avoid? ( just like the case on BOSCH PLUGS almost everyone here hate it )
Some good Ideas that the FSM didnt mention?
Proven recommendations like NGKs are the best plugs for SR20DEs?
or anything.....
1 - 18 of 18 Posts
