I am going to use the Ground Control coil-overs from my friends 96 SE-R and I was wondering if the spring height was any different than the G20 ones. I am also going to pick up a set of the KYB AGX for all four corners. Where is the cheapest and best place to buy the KYB's. I have found $370.00 shipped. Anyone with used AGX's? Thanks for the help
viet-g20 said:
um.. i dont think the suspension on the p10 and s-er are the same... i maybe wrong though
You're at least half right. The SE-R uses a strut type front suspension and the G uses a multi-link front. So I know the shocks won't transfer over. Rears won't work either unless you had a P11.
However if you're just talking about a threaded collar you might be able to work something out. I don't have much experience with the GC though. George can probably let us know since he has more experience with GC's.
