http://www.steelseal.com/eng/howitworks.html
anyone ever tried this before?
the af is getting into the combustion chamber. they said that it will work only on small cracks... and i dont think mine is all that big.for 44 bucks i think imma try it. at worst, if it doesnt work, i'll get a new motor, as that was what i was going to do anyway...at this point i'm just curious to see how well this stuff works... i'll let you know what happensechandler said:i used not this stuff but some other stuff from shucks it worked for a bout 3 months and then had to use it again but then the car never ran cool and eventually the headgasket blew between the cylinders so there was no compression in two cylinders and it finnaly had to get replaced. this stuff will only work if coolant is getting into the combustion chamber or oil, it won't work if it can't get to to the break threw the coolant.
No it isn't ............... Its freakin' impossiblesentra024 said:the af is getting into the combustion chamber.
Dont you usually have to take the head in to get checked and shaved if you blew a head gasket?Yahnozha said:hell, just buy a headgasket and replace it. at $44 your just about there.
