I was wondering if there is a way to take out and clean the left headlight lense on my 92g. A bulb exploded a long time ago so it is foggy and does not look nice and clear like my other one. If there is a way to do this please help me with it.
cleaners
To remove the carbon use a citrus based cleaner like :
Goo Gone
Goof Off
Sticker off
-or-
try using:
WD40
Bug 'N' Tar Remover
Put a little bit on a rag and use some elbow grease to get
the area clean.
You can find all that stuff at Home Depot
rub it with your mini-hand??
If I'm not mistaken 92g has some nastyness "inside" the glass light casing?? you'd have to have quite a small hand to "use some elbow grease" inside the 2" or so dia. hole that the bulb goes into....
The actual lense is covered with something on the inside and is cloudy looking with the headlights on. My right one is superclean but the other blew a bulb I think. How can I take just the lense out?
